Quick copy of existing channel
I want to quickly copy a channel and settings and paste it to another channel . So, eq settings, compression and etc. what would be the easiest and quickest way to do this in real time during a live show?
2nd question , if I wanted to completely copy a channel , name and all, an exact copy and paste it to a blank channel?
Thanks :slight_smile:
There is already quite a long post about this here
Nothing has changed about this in the meanwhile… sigh
So from what I gather in the post mentioned above, the following will achieve copy/paste functions. This is for dlive .
Copy + Sel copies the channel processing.
Copy + Mix copies the mix assignments and send levels.
Yes, exactly.
Copy/Paste + Sel copies/pastes all channel parameters (Sans Dyn8 if on insert.)
Copy/Paste + Mix copies/pastes all mix parameters/assignments for that channel.
