Please update the app to ios 15. There are many display glitches …
"Display Glitches?"Greetings Really... I have not tried since updating to IOS 15 just yesterday. I'll have to go test. I'll have a look and get back.
yes, sometime UI flashing randomly but, most important, some UI parts are gone. The app is unusable. Please, update it
Just powered 1st gen iPad up and seems fine?
Using Qu-Pad version 1.93 and qu32 version 1.95
IOS 15. Router is an old Apple Tall/Square Jobby which I havent touched in …5 years
But then I dont often use this very often now at this moment
I cant see anything missing.
I’ll leave it running a while.
Cheers
Many display issues with iOS 15. The app is mostly usable but need an update ASAP. We use a QuPac and without the app functioning properly it make things very difficult.
Hi all,
Please provide more information to us using support.allen-heath.com so we can have this looked into.
We need to know the iPad model name/number and iOS Software version (which can all be found in ‘Settings - General’)
Please also let us know if any particular action is triggering the flashes, what is meant by ‘glitches’ and what exactly is missing from the GUI as we have not seen any of this in our testing.
Thank you in advance.
I’ll post here and try to submit something through the support link.
I’m using an IPad Pro 12.9 inch 3rd gen - model A1876
iOS 15.0.2
The gui gets pushed because of the bars that Apple has added to the bottom and top of the screen. I’ve attached an image as well.you can see the gui is pushed and makes some things hard to get at.
I’m using iPad Air 4th gen. Mod. MYH62TY/A
IOS 15.0.2
As you see in the yellow circle, the mute buttons are cropped and unpushable. Sometime flashes appear randomly on channel strip area.
UI does not fit the display (red arrows)
iPad Pro 12 inch 1st Gen IOS 15.2
All looks fine in Demo mode looking at all of the Templates
Nothing missing off the screen.
I have no bars along the top or bottom
Same troubles…. IPad 12,9“ Screen does not fit…. !!
Same problem here:
iPad Pro 11 iOS 15
It’s about time that A&H updated the app to fit the modern iPad sizes
Are we ever going to get a fix for this?
Update? Is anyone from A&H listening? The UI issue shouldn’t be that hard to fix. 4 years with no maintenance updates is a little frustrating.
Sorry this has taken longer than we’d like, but unfortunately it has required a large rewrite and isn’t just a case of a couple of lines of code.
The good news is that it is currently being worked on and we hope to have a release soon.
Thanks for the update. I’ll try to be patient. I was hoping for a simple code edit. Sorry to hear it’s a lager rewrite.
