QuSB Livestream Inquiries
Hi there, folks! I do sound for our church using the QuSB console. The people who hooked up the system connected the Qu to AR2412 stage box via DSnake and using the 8 XLR outputs. What I did was to connect a Focusrite to the the 5 and 6 outputs of the Qu and run the interface via USB C to our Mac Mini. My question is, is there a way for us to have a separate FX sending for the livestream and the FOH given the setup that we have?
If you assign the fx-return(s) to a separate mix into a separate output you could feed that into your interface ?
On the other hand: if you connect your computer directly to the Qu-SB via USB you can record the fx-returns directly to one or more of the 18 available tracks (see IO-patch / USB Audio).
Good luck !
Giga
