On my R72/idr32 I needed additional MUTE GROUPS, but have already assigned all 72 faders (including 4 DCAs) - I may have found a way to get extra MUTE GROUPS via SOFTKEYS without needing any faders…
Perhaps this is already well known, or may be unstable, but seems to be working so far on the bench…
I SELECTED DCA #4, reassigned this fader to DCA #9, assigned DCA #9 to vocal channels, assigned SOFTKEY #1 as its MUTE GROUP. I then did the same procedure (same fader #4) using DCA #10, assigned to instrument channels, softkey #2 as its mute group, and finally reassigned the fader back to DCA #4, original state. I’m going to play with this a bit on bench, and if it seems ok, I plan on adding 2 or 3 mute groups this way.
Yes this will work - the DCA’s are part of the mixer so are aways there regardless of wether they are assigned a channel strip or not. The soft keys if assigned to them will work, as will using any programmed midi controller or TCP/IP command.
I’ve set up 4 mute groups this way - they must be saved in the scene, I found out, but looks like I’m going to use this.
Thanks for the info on midi… does this mean there are ways to get to mixrack functions that are not set up in the original show? -more FX units, matrices, etc.? I am a “mid-iot”, but know some locals with some midi chops, extra controllers, etc.
Yes! With midi you can access and control all channel faders, mutes, pans (inputs,fx sends, ip fx,DCAs, plus all mix outputs) DCA and main mix assignments, all PAFLs, and scene recalls. You can even name and colour strips if you know what you are doing via MIDI.
I have now modified that old environment to work with the new midi features introduced with Editor version 1.8 along with logic version 9 and it works extremely well. If anyone wants a copy of my new “MC-iLive V1.0” logic environment then flick me an email. It will work with any midi controller that uses the Mackie Control protocol but you will need Apple Logic v9
No you can’t adjust any mix sends other than the main fader levels via midi - so to clarify above where I said “fx sends” what I mean is the fx or aux MASTER fader levels only. Still midi is really useful especially if you just want a few extra faders or DCAs
