Ive had my QU-24 for three months now, and every so often, it generates an electrical noise during playback (via usb) in the studio. It happens sporadically, and it’s embarrassing when I’ve a client in, and we notice it… and have to re-do the recording.
I had to send a client home tonight because it happened four times in a row.
Has anyone else had this problem, and know how to fix it?
QuDrive or USB B? What are recording on? What else is connected?
What’s the noise like? Any chance you can post a sound file?
You say it generates the noise during playback, but then that you have to re-do the recording, so is the noise recorded - and therefore generated during recording?
To be honest, diagnosing this online is going to be tricky, but I’m sure people will try if you can give them more to go on.
Here’s an audio demo of the noise. Believe it or not, that’s the quietest it gets, and it happens with every recording session, on all channels… not just input 7 for example. It happens inconstantly, All armed and recording channels will take this noise during recording (unheard), then during playback, it’s heard at the same place in the recording. USB Streaming.
What USB cable are you using? I had a big problem with long thin cables. Always electric noise on all channels. Using a big one with EMI filters solved the problem. Or one with a repeater.
I think the cable has to be a good one, not a cheap one.
It seems I can’t access the track on SoundCloud. Can you submit a ticket to our Product Support team and attach or link to the audio file, this might help us troubleshooting the issue. Also include what version of OS X you are using, what DAW etc.
Just for completeness I should point out that my recording was from a completely separate system, so it’s not necessarily introduced at the recording stage.
I’m using Reaper to record, as seen in Allen and Heath instruction videos. I’ve been using Reaper for years, and I’ve never had this issue until i got this new Allen and Heath QU-24.
My desk is out at the moment, but I’ll try to record what I hear - it’s a longer/louder version of the initial spike of noise on the above recording, without the “tail”
I’m using a February 2014 iMac. Everything that should be plugged in, is. I don’t know if resetting to the old original Firmware will help, but I may give that a go.
Vega, did you ever figure this out? I’m having the same problem with a QU-24 board that is brand new. We have L/R going into MTX1-2 which then goes out through USB streaming. At random times and for random durations we get this electrical noise. We have tried changing out the USB cable for a higher quality, shorter cable and also have made sure ST3 is muted and we get the same problem. We are streaming to a Windows machine normally (only stereo, not multi-track), but have tried a Mac and the same issue occurs. Qu-Drive recording works flawlessly.
I had the same exact noise on ST1 (USB B streaming) back to the Qu-16 desk from SONAR, it would happen at random intervals on the recordings. I tried increasing the latency but that did not work. What wound up working for me was switching the USB cable to another port on the computer and it seems to have corrected the problem. Thanks to [XAP]Bob for the suggestion!
I spoke too soon. The noise reappeared all on St1 ST2 and ST3 during USB B streaming playback. Maybe I’ll look for a USB cable with the magnetic shield?
FrankieFender,
If you’re still watching this thread-
I wonder if you could check to see if the noise you’re describing is in any way related to having phantom power engaged for a while.
I’ve had a similar issue, although not recently. I’m just trying to eliminate possibilities.
