when it will be released a firmware to record using the qu pad applicati on for ipad?
Define record?
If you want the iPad to do mulittrack recording then it already can.
Of course it needs DAW software, and a “camera connection kit”…
Thanks for the reply. On the touch screen of the ‘qu-16’ is the function ‘qu drive’ to record in stereo or multi-track, but by using the ipad app ‘qu pad’ I can not do. Why Allen & Heat does not implement this feature in app ‘qu pad’?
Well, I do it by defining a couple of soft keys, and using them from the QuPad.
Arm/PlayPause/Stop
Thanks Bob, I don’t know all the good features of this mixer, I study them when I need, you have enlightened me with a few words. Thank you so much and I hope you can help me in the future.
The manual is a good read
It then sometimes takes a little bit of lateral thought to achieve exactly what you want to do…
PS - I’m serious about the manual - I had read it cover to cover several times before I decided to buy the QU. What I learned about the other mixers has mostly slipped from my mind, but I use the QU reasonably often (at least once a month) so I tend to have most of the block diagram in my head - as I do with the Roland M300 (which I have installed at church, and also use regularly) - but the X32 is less well defined, despite having read the manual, since I don’t use it often.
I’ll take your advice seriously. Thanks again…?
