Recal Save issue
I´m working for the first time with recall safes and have the following thing with it.
I create a recall safe setup as I like it.
Then I make a strip recall safe with the button on the surface. I put the strip out the recall safe with the button of the surface and go back to the “recall safe edit window”. Now my setup for this channel is gone. Everything is “off”
This is a bad behavior
V1.81
ThomasB
IDR 48 T80
did anyone follow this up??? A&H?
Current stock:
2x T112, 2x R72, 2x iDR-48, 2x iDR-16, 2x xDR-16
4x Dante Cards, 3x ACE Cards
How about updating to the latest Firmware Version first and then try if this issue still exist and THEN post it.
Cant understand why so many people still not updating to 1.83 - takes about 5 minutst time. [?]
To be fair 1.81 was current in May 2011…
Hi Thomas
This is how the scene safe system was designed to work. The scene SAFE button on the surface makes all parameters SAFE On or Off for that channel. The scene SAFE icon on the LCD display will only be illuminated if all parameters on that channel are SAFE.
Regards
Sam A&H
1.let scene SAFE button all OFF.
2.Recall the scene againe.
