Recall Filter vs Global safe
Hi
I am new to bigger Live events. so i was learning about scenes and i came across this weird confusion.
What is the difference between Global safe and Recall filter in Dlive systems?
Does both of them does the same job while recalling or changing scene ?
Kindly bear with me if it is a stupid question.
Josh
A global safe stays in place for all scenes, whereas a filter is specific to a particular scene.
One thing to know about dLive scenes - there is a “base scene” #65535 that appears to represent the current state of the mixrack at all times, including bus configuration and items not recallable in scenes. When you save / recall a show, this scene is always saved and is the basis for everything that is global/role safe or masked off by recall filters when a show is loaded. There is nothing you can do directly with this scene, it is always the mixrack state at the point of the save.
It also means, unlike other desks, you can save a show with no scenes stored and still have it recall to the point where it was saved.
Jay
I have another question about this subject. I have the sq7 and Avantis board. When you setup your safes does that stay that way all the time. For instance if I was to recall a scene or a show from a thumb drive does this area stay the same way or does it follow what you are loading from a thumb drive if not what do I have to turn on or change so it will change when loading back onto a desk. I am also new to doing this for theater any help will be much appreciated thanks mike
