Recall show manager from QU-7 to QU-5D
Hi Everyone,
Does anyone been try recall show manager from QU-7 to QU-5D?
Is that working on it?
I did setting on input and output including processing EQ and Delays on QU-7 and owner of Hall will swap to QU-5D.
Is that can work? all my setting will work, or i will redo from beginning.
thank you.
Hi Roni,
Yes, you can move your show file from a Qu-7 to a Qu-5D. You’ll lose anything that doesn’t physically exist on the console - fader assignments beyond the physically available faders, and input assignments to IO that doesn’t exist locally on the Qu-5D, but otherwise it will restore everything OK.
(This is the same in general across all our products - you can share show files across consoles of the same mode type)
Hi Mark,
Thank you for response,
yes, i have all my setting in new console, but my custom layer doesn’t have fader on right hand same like qu-7, like you said:
but it’s ok will re arrange again based on performer. My saved library also move to new console already.
Thank you.
