I have a stereo aux used as an IEM feed and I want to save the settings in two scenes so that I can switch between two different configurations depending on who is using it. Effectively allowing them to save their individual personal monitor mixes.
I can store those scenes easily enough and recalling them does the expected thing. BUT I don’t want the recall to change anything else. So naively I thought the way to do this was to block everything except the routing for that mix in the recall filter. Seems logical since the settings of the inputs to the mix are shown in the routing tab for the mix.
However, this doesn’t seem to work. the settings (i.e. the levels, pan pre/post, on/off settings for each channel feeding the aux) don’t get changed when I recall the scene with the filter.
I’ve found that allowing the routing of each channel which is input to the mix works, but initially thought that that would potentially affect any other mixes they were used in.
Or is it the case that the combination of the routing of the input and routing of the mix restricts it to ONLY those inputs in THAT mix?
That SEEMS to be the case, but can anyone confirm that is indeed how it works. i.e. the only ones that get changed are the intersection of the allowed input routings and mix routings?
BTW I’m still using 1.42. I’m waiting till after Sunday to upgrade to give me a full week to sort out any issues. Not that I’m paranoid or anything ![]()
