Recalling a saved Channel in its entirety
We save channels to the channel library in order to reuse them in their entirety.
Saved channels are problematic in the sense that all is not saved and the channel name is not easily recovered.
Channels, for our workflow, represent one of many specific vocalist or instruments. To swap out a vocalist channel for another, the channel strip is highlighted, and the channel library is opened. The replacement channel is selected, but “the name of the channel does not replace the existing highlighted channel” to be replaced. The user has to retype the channel name that is replacing the highlighted channel, otherwise, you have a new channel replaced in the strip with the replaced (old) channels name. If you would make the channel name sticky (or option for sticky name), then this would not be necessary. In addition, the D-Pack tools, such as the Dyn-8 settings are not saved with the channel in the channel library. Neither is the aux out fader setting associated with the channel. Very much prone to user error.
I made this same basic request as well. I’ve been using Avid desks for over a decade and when recalling a channel, all aspects are recalled including routing to various busses (monitor auxes, fx sends, groups, DCAs, etc) along with the name. It’s very frustrating that such a logical feature is missing from these desks. I can setup a show from scratch with an Avid desk and my channel presets in a couple of minutes before soundcheck once I have the input list. With Avantis, I takes 10x longer…
My thread on the issue:
https://community.allen-heath.com/forums/topic/input-libraries-should-also-store-recall-bus-assignments
I’d like this too.
I too was a long time avid user who converted and was very surprised to not be able to save and store all of a channel’s info as well as copy and paste.
+1 I would like the name to recall. And the dPack inserts (dyn8, de-Esser, etc). Those are part of the channel.
I sometimes don’t want the auxes to recall (though sometimes I do), maybe some of these things could be set as a “filter” that chooses whether or not to recall it, just like the preamp currently is. And then by default have everything set to recall (having to toggle on the preamp setting every time I turn on the console drives me crazy!).
+1
+1. I don’t actually necessarily care too much about name/color, but other parameters like routing would be very very (very) useful.
+1, especially being able to select what is recalled
+1 - YES PLEASE! - Would be good if the routing was stored and recalled from the channel library (like most desks I know!)
I just started a new thread on this named “Channel Presets” forgetting that I had commented on this thread a year ago. It’s clearly still an issue.
+1 I came to the forums hoping for an answer to this problem, but count me in as well.
We use the library for drum channels.Faders and sends are an important part of the sound from one drummer to another, and makes it MUCH faster to recall a given player for the weekend.
+1
+1 from me as well on this.
I made a video yesterday of how fast I can set up a show on an old Avid Venue. A&H product manager folks, if you have not ever worked on a Venue and used this feature, I highly suggest you rent one for a few days and see what a difference it makes and workflow to have this capability. https://youtu.be/orX6jssSk3Y?si=DK_0iGIKC_SHr2Vs
+1 for full recall.
Coming from the SQ It surprised me that this was not the case when I wanted to use the function for the first time…
Cheers
+1 Finally upgraded Avantis to DPack and am very disappointed this doesn’t exist. Having to manually configure the full channel each recall makes the recall… Only somewhat helpful…
I DO understand that with 16 channels of processing, you might be unable to recall settings on a channel if there are no DSP resources available, however, the default IMHO should be to store it all, and on-recall, throw a warning in the event the DSP resources are all used with the option to override with “apply all available settings on present” or “cancel”.
This seems a little bit elementary… Maybe there is a legit reason that this doesn’t exist, but I can’t think of one…
+1
I’m also a bit disappointed that a channel cannot be stored in its entirety, and even more disappointed that I am not able to recall what has been stored into a new show.
Wrenn
The DLive consoles do this as of V2.0, they should migrate that feature to Avantis for sure
