Hi all,
I’m sure this has to be addressed somewhere on these forums already, so forgive me, but the best I could find was this one - https://community.allen-heath.com/forums/topic/sq6-send-20-channels-to-one-stereo-out-for-streaming-how. Basically, I’m needing to connect a livestream mix out of the SQ5 to an ATEM Mini, which has an unbalanced 3.5 mm mic input that you can set to accept either line or mic level inputs.
So far, I know of the following:
Option 1: Using AUX 1/2 as a stereo output (with 2 XLR to 3.5 mm cable) works if the ATEM is set to line level, but lots of distortion and loud humming if set to mic level. I’m also concerned with XLR to 3.5 mm in case phantom power gets sent.
Option 2: Use the TRS A and B output (need both to be stereo?) and use a mono to stereo TRS cable to the 3.5 mm input.
Option 3: Use either of the above options and feed the output signal to a camera, which gets the audio into the ATEM via HDMI. I’ve seen this setup mentioned as a way to get around the balanced output / unbalanced input issue. I tried this setup, but was still getting high levels of distortion/humming (~-30 dB).
Am I missing any other options? I don’t want to use the headphones out option and lose the ability to monitor at the board amongst other reasons.
Finally, for context, I’m relatively new to the SQ5 board. I’ve been watching lots of videos to get a crash course and am getting comfortable with it now, but still have a lot to learn.
Thank you for any advice!
