I spend lots of time today to figure out how I can record L en R from a qu-drive recording on my MacBook using Audacity, just as it sounds trough the speakers.
It is working in a way, when I record 18 channels and remove the first 16 after the recording is finisched but here is no FX1 and FX2 involved in the sound recorded and that is actually the whole point: doing the mixing on the QU-16 and preserve it on my MacBook.
Hints, pointers and solutions are very welcome. Thanks in advance
Bob, thanks for the effort to respond to my question. The idea is that I use the 16 tracks for final mixing after the performance on the Qu-16. The FX1 en FX2 returns were up. The FX1 and FX2 could be heard over the headphone plugged in into the QU-16 I was using during my mixing activities and the headphone is getting louder when using the L / R fader so I assume that what I hear over the headphone is the same as the L / R channels as long as there is no PAFL button touched.
So what I’m aiming for is to simply record L in channel 1 of Audacity and R in L in channel 2. For now I miss Fx1 and Fx2 in the L /R recording and I have to record 18 tracks to get channel 17 and 18.
Have you checked the QuDrive routing, IIRC it is 1-16,L,R by default and the L,R should contain that mix bus, i.e. what is pumped out of the FOH (although probably PreFade)
You mention recording in Audacity, which makes me wonder if you are using the USB connection to a computer rather than QuDrive…
In which case 1&2 can be made L&R by changing the USB routing on the appropriate menu. The QuDrive can have L,R,3-16,1,2 as easily as any other combination. That would also give the USB B connection L&R on inputs 1&2
Bob, I use a USB cable to connect my MacBook with the Qu-16 mixing table. To be honest, until now I’m a bit scary to change default routings and settings because of unexpected results and problems to reverse the changes. I have to invest time in the near future to overcome my fear and to master myself in adjusting the table to my own needs. Can you please give a pointer on what the appropriate menu is.
This afternoon I will play around with yesterday recordings and try to find my way in the menu’s.
I’ve never been able to record anything besides channels 1&2 to audacity. I found a MP4 recorder that does the job for $20. The interface is a little hokey but it does the job. With it, you can choose any channel pair you want. https://tapedeckapp.com/
I could never get just a stereo recording from the main L/R Buss. I guess if you add enough channels to your recording you will eventually have them all including the main out but I just wanted a stereo recording I could quickly burn to disk.
Reading the manual should clarify things for you…no fear…
Bob suggested a good solution…
if Audacity can not configure the recording devices itself it should be done with the system control panel
Core Audio on the Mac.
there should be a routing posibility as well instead of the QU
Why not simply switch over from Audacity to Reaper when it comes to multitrack recordings? Compared to the cost of even a Qu16 the additional USD 60 registration fee (for individuals and small business) is nothing but you get a stable, low latency, lightweight, full customizable, VST aware, ASIO based recording situation on both Mac and PC…
Was my first after-Qu purchase even that I am a longtime Samplitude user…
I’m with Andreas.
you can even try Reaper for free.
I tried the Audacity and it confused the heck out of me.
Reaper just works with core audio and QU.
Its worth the “time investment”
If you watch some of the A&H sales videos they have REAPER on their mac screen.
Just a random question - can you get Audacity precompiled for ASIO nowadays, I recall when I last put it together on windows that I had to compile it myself - because of some licensing with ASIO maybe?
ASIO is bound to a license incompatible to open source, so things still are complicated to get Audacity running with ASIO nowadays.
…for me at least more “complicated” than just spending 60 bucks for Reaper and have fun…
(did I already outed myself to be a programmer on several platforms with necessary tools ready to use???)
@Andreas and @Dhak, Sunday afternoon I was with a friend mixing the Qu-16 recordings of his blues band and he showed me Reaper and I installed it on my MacBook. I have played around with it for a couple of hours and it looks and feels great although all the options are a bit overwhelming. I haven’t tried it out as a DAW but I think I followed your advice before you even gave it. I guess that means the problem, as far as Audacity is involved, is solved because I will not use it anymore if Reaper runs fine as a DAW.
I wish I could get the L and R main mix Via USB on windows 7 all I every get is 1 & 2 no matter how much routing changes I do, i simply want to mix on the fly using the built in effects and save a LR recording.
Already said multiple times within this thread:
Manual 8.14 “Output Patch Setup - USB Audio”
Per default LR is assigned to send channels 17&18 (QuDrive Stereo Recording) but from that screen you easily can feed LR to first two streams as well.
…maybe missed to press Apply???
