So, I bought this wonderful device thinking I could record live Without the use of a computer. I get that I can record all 16 channels plus a L/R but what I DON’T get are the 2 stereo channels! What a waste as these channels are ideal for keyboards with eating 4 other mic pre channels. I would really, really love to use it to record live but leaving these channels out or making me lug a separate computer is just silly to me.
Guess I will still need to use my software audio console rig…
Sure, QuDrive recording is limited to 18 channels, but you’re free to choose which sources you wish to record. These include any channel and any Mix/Group/Mtx/Fx etc. source available. You may want to re-read chapter 11.18 in The Manual.
So, I did read that chapter (apparently correctly) and my issue is that I want to record 18 channels (1 - 16 mics and the 2 STEREO channels that I use for Keys) and apparently the QU sees that as 20 even though you have control over ST1 and ST2 ONLY as a stereo channel. So, my wish is that I can record all of the hard input channels to a USB drive. They were so close…
Sure, we all want to record all physically available channels on QuDrive, but that’s physically limited to 18 (mono) channels, it can’t record 20 channels. But you’re free to pre-mix some channels and record the mix to capture all physical inputs with the available 18 recording channels. Thats a standard procedure on a Qu32, for example.
I realize it is limited to 18. My point (and hope) is that they would extend to all hard channels as high speed use drives are common and cheap. If they can pass 18 they can pass 20…
…limitation could also be number of audio paths between the mixer part and QuDrive engine…
I’m pretty sure we had seen an increase of QuDrive channels for the Qu24 and Qu32 if there wouldn’t be some kind of hard limitation.
Yes - there are a number of places the limitation could be. That the limit is the same on the 24/32, despite the additional channels on the USB-B interface does imply an internal connection limit - maybe determined by some other limit we don’t know about.
It’s not like they hide these limitations of the qu-drive. Ya i agree getting more would be swell, especially for the 24/32 owners. But you know what you have to work with, and there are different ways to work around the limits as others have said.
On occasions where I have less than maximum guitars or vox/horns, I can add more drum mics, but I rarely bother since Glyn Johns or Kick/Snare/OH-LR suffice for my mixing needs.
On occasions where I need more channels, I can run the keyboards on ST1-Left & ST2-Left to USB 15-16, freeing up two more XLR channels for mics or DI.
If you need more channels, can you provide an input list of your typical requirements?
The simple solution is to use USB-b streaming of 24 channels to a dedicated hard drive. I use an older Seagate 500 gig drive I had laying around and got lucky that it’s fast enough to work with my Qu-16.
For Qu-drive I use Sandisk Extreme 16 gig sticks…which work flawlessly for me. I pick them up in 3 packs when I see them on sale and have a dozen or so. Total investment is probably a cuple hundred bucks. They’ve paid for themselves long since. The Seagate drive was on sale for $80.00 a long time ago.
I’d recommend searching for a compatible drive and taking advantage of the expanded track count available via USB-b streaming… Utilize what’s there for you. It’ll be a LOT quicker than waiting for the industry to cater to your individual needs.
