Relative levels with actions
Can we get actions to change the relative levels eg. when you trigger an action de send level will go +5dB and when you press it again it will go -5dB relative to the actual send level.
This would be HUGE for monitor mixing from FOH!
Need to boost a solo in certain mixes all at the same time? Boom! Solo boost button. On/off. Relative levels would be key since you don’t know what the starting level will be for that fader every night. Monitoring post fader from the main mix isn’t great either, cause the band might not want to follow the house mix for the majority of the set, and may want a boost that’s less or more than the fader ride in the house.
