Is there anything on the market that could be used with the QU (dSNAKE) that has 1/4" or Combo input jacks? It seems everything A&H offers is all XLR. I have a studio synth rig with 24 channels of outputs that I’d like to use with it (w/o the need of many DI’s)
If they are balanced inputs then a simple cable will do the job - XLR to TRS jack…
If they aren’t then a simple cable will do the job, you just will be subject to the same interference on the cable as you would have been anyway - the XLR inputs will take an unbalanced input - at least they aren’t carrying it to the mixer unbalanced, it’s digitised for that link…
Thanks, they are a mix of balanced and unbalanced. I was just trying to avoid additional cabling, adapters, etc.
How are the outputs presented? If they are sockets (which I’d expect) then you’re replacing cables, so no more anywhere other than your storage cupboard…
A set of adaptors (rig might well have cables as the output) or cables (if it has sockets as outputs) should be a clean enough solution in a studio.
A 1/4" TRS jack to XLR male loom would be the most appropriate solution here, assuming the jack sockets are located together.
DC
I hope the link is working
thats the solution from my cable dealer
That works, and would work…
Woodwork will never solve this problem - you need something that conducts electricity. ![]()
You need more electricity, then most things conduct it ![]()
