I was wondering if you can take an input out of the main mix or house? On my old Behringer X32 I was able to hit the L/R button to remove from main mix. My issue is the main musician uses a talk back mic to communicate with people in their headphones and in-ears.
Yes, no problem.
Okay, how do you do it? Thanks
On the LR mix, press the assign button to the left and de-select the channel(s) you want to remove from the main routing to LR
We do this with a pair of room mics and piano mics that are routed to our livestream, but not to the main L/R FoH mix. Page 42 in the SQ Reference Manual explains how. See attached image.
In the example in the manual, ip1 (Input 1) is the selected channel and you can see all of the potential outputs for it. Notice MainLR is the first option and it is currently ON; tap the ON button and you will un-route Input 1 to MainLR.
Hope that helps,
-don
The assign button is much faster.
