Hello,
I have a GLD T80 in which I just replaced all the fader banks, and is working perfectly, except the encoder knob near the touch screen (the one that controls whichever parameter is touched within the screen) is…stuttering badly. If I pull up or push down on the knob while turning it works better, but still not perfect. If I try to turn it without pushing/pulling, it hardly works at all. I found the part onlne: https://www.fullcompass.com/prod/513340-allen-and-heath-ai8567-gld-80-encoder-no-switch
But, before I tear the thing apart again, does anyone know if this is a simple solder or tab connection or is this thing directly connected to the circuit board trace? If so, I should probably just send it back for repair but I would rather spend $12 than a few hundred.
Chris
