I have rent a t112 to a client and the sound engineer have put a password and he forget it and now he can’t work with it …what to do for total a reset of the sys ??? help !!!
quote:
Originally posted by Focus StudioI have rent a t112 to a client and the sound engineer have put a password and he forget it and now he can’t work with it …what to do for total a reset of the sys ??? help !!!
from the user pdf files
Note: Only set passwords if you really need to.
Make sure you keep a log of all passwords
allocated. Clearing passwords required resetting
internal jumpers and clearing the memories.
RayS
R-72/iDR32/iPS10
dam…
thanks you comfirm my fears…
Contact Tech support - They can advise how to clear the user accounts only. You don’t need to totally reset everything.
Cheers
Richard Howey
Audio Dynamite Ltd
IDR48/IDR16/T112/R72
thanks…
T series uses dip switches instead of jumpers…access from rear of mixrack/surface next to midi connectors
switch 4 is for resetting password users etc…
RESET PROCEDURE
Power OFF.
Move appropriate switch to UP.
Power ON. Allow system to boot.
When system has booted – power OFF.
Move switch to DOWN.
Re-boot system.
RayS
R-72/iDR32/iPS10
hi,
got same situation here- iLive has 2 users defined, Admin and user. Cannot switch to Admin, password lost.
Tried what RayS suggested, however there is no switches at the back of mixrack, nor the midi connectors.
I assume it was surface mentioned, so I found 4 dip switches, but after completeing these 6 steps still can’t switch to Admin.
Anything more left to try?
ddff
ddff
at the rear of your mixrack for iDR 32 and 48 and rear surface for T80 and T112… small round black plug??? on surface reset is dip switch 3…give me your email and I will send you the pdf…
from the pdf file
RESET SWITCH FUNCTION
Switch 1 Resets mixer settings
• Processing - current settings [iDR-32/48]
• Strip assignments [T80/112]
Switch 2 Clears all scenes [Both i-Live and iDR-32/48]
Switch 3 Clears configuration sector
• Input setup – mono and stereo channel settings [iDR-32/48]
• Mix configuration [iDR-32/48]
• Buss configuration [iDR-32/48]
Reset user profiles
User names
User passwords
User permissions
User default power-up scene
• IP address [Both T80/112and iDR-32/48]
Switch 4 Reset user profiles. [iDR-32/48]
• User names
• User passwords
• User permissions
• User default power-up scene
RayS
R-72/iDR32/iPS10
Right,
I got R72 and iDR16 here, but I managed to find out what the password was.
ddff
Any other advice on this issue? I bought my iLive T80 and iDR32 from an auction of a company gone into liquidation. I dont have access to the admin password at all.
Ive tried flipping the 4th dip switch up on console for boot process and it had no effect. Also my iDR32 has the black plug but no dip switches, is this unusual?
The dip switches are behind the black plastic cap - did you remove it?
Cheers
Richard Howey
Audio Dynamite Ltd
Hi
We changed the non-modular mix racks to put the dip switches inside the Port B slot, on the right. This was because the iDR-16 PSU board mounts vertically behind the Main Board, blocking any access to rear-facing dip switches. There may have been a changeover period where a rear panel with the black plug was used together with a newer Main Board, which had the revised dip switch location.
If you look inside your Port B slot, you should see a set of 4 dip switches on the right hand side. These function in the same way as before.
Hope this helps.
- Jeff, A&H
Aahh - that explains things! Thanks Jeff
Cheers
Richard Howey
Audio Dynamite Ltd
That is the info i was looking for and yes it is behind the port B faceplate. Worked a treat. Thanks ahjeff
