Return from qu 16 in to logic for export project whit effects of qu 16
Hi guys I bough just 4 days ago qu 16!!!so I already setup for send signal from logic to qu 16 but I don’t know how setting routing for return from qu 16 to Logic Pro x for bounce (export) the project whit Comp eq ecc ect of qu 16!!!
Please help me whit easy way I’m beginning thanks in advance
Any help???
…maybe there already are too many threads with similar setup questions around… :wink:
If you already can play from Logic through the Qu and hear what you intend to hear via LR, just use the default USB Output routing and record LR (should be channels 17&18) in Logic.
Reading section 10.16 in the manual may be helpful, sorry…
First all thank you for reply !!! Ok I’ll try this way I let you know thanks again
Thanks a lot Andreas it s working perfectly now ???
You’re welcome. :wink:
