Volounteer,
You said some of that correctly, and some sounds not quite correct.
The QU routes one effect to only one of the following choices; 1) single channel via insert, 2) single mix buss via insert, 3) single FX buss, and 4) single channel to a different single channel to be used as a 'return fader. A single effect can only be applied to multiple channels using one of the 2 FX busses. But, yes, once the 4 effect slots are assigned to a channel/mix bus insert or an FX mix you are out of assignable effects.
For example, I have a gated verb, FX4, on the snare channel. FX4 is not available to assign to any other channel, mix, or FX buss. To see how this works, press the FX button and go to the FX slot you want to assign and press the ‘Front Panel’ button if you cannot see the assignment screen. The QU looks here to find where the effect signal is coming from and where it will go after assigned. Once you select the ‘Inset’ assignment, you can only pick a channel or mix to use for the ‘insert loop’. This is very similar to an analog mixer, using an insert cable from an effect and plugging it into the ‘insert’ jack on the channel or mix you want to insert the effect on.
I have an SQ5 and a QU16, and this is the same on the SQ also. But on the SQ, you can subgroup channels in ‘groups’, then apply a common effect as an insert. This is easiest to understand my imagining a specific compressor setting applied to all the drum toms. But, again, one setting applied for all the channels in the subgroup. I believe the larger frame QU mixers also have groups, which could be used in this way. All QU mixers have DCAs, but it’s important to mention you cannot insert effects on a DCA because DCAs are not actual busses. DCAs are simply a single fader that ‘moves’ all the physical faders in the DCA the same amount at the same time.
You mentioned running a single effect for multiple vocal channels. There are only 2 FX busses on the QU16. If you need more, I can only think of one work around for you on the QU16. It’s a bit complicated and it requires losing a Mix aux out and a ST input for each set of ‘grouped effect’ channels, but it can give you 2 more pseudo effect return busses if you can spare the mix busses;
- Set up a mix buss, say MIX5-6, to be assigned Post Fader.
- Because mix busses cannot be assigned to anything other than an AUX out jack on the QU, physically patch the MIX output jacks, MIX5-6 in this example, back into the mixer via the ST1 input jacks using patch cables.
- Pick an effect slot, assign the desired effect to that slot, and route it to insert on MIX5-6.
- On the MIX5-6 layer, select each channel send like you would an effect send buss. Remember, because it’s a post-fader buss, unity gain (0 db) on the fader will send the same signal to the MIX5-6 Master as is set on the actual Layer 1 channel fader.
- Set the MIX5-6 Master at unity gain.
- Send signal into the mixer. Check to make sure the input level to the effect is at or below 0 db. Then set the ST1 input trim to make sure the input stage is also at or below 0 db so it is not being over driven.
- During soundcheck, use the ST1 fader on Layer 2 to set the amount of effect you want sent to your main mix speakers.
This method allows you to set the channel EQs and processing uniquely before it is sent to the effect, but the effect parameters would be applied the same for all channels sent. Also, for easy on/off control of the effect, you can assign a Soft button to mute MIX5-6 output. This will make sure the effect will ‘spill’ until, say, the echo repeats are done. If you want the mute button to ‘choke’ the effect instantly, assign the mute to ST1.
This how I used to buss outboard effect units from an output aux buss back into a stereo channel input on analog mixers for better control and EQ of the returned effect sound. You can also do this with another effect slot because there are 4 effect slots and only 2 FX busses. Just use one of the other stereo mix buss outputs and ST2 for the return patching.
There may be someone more experienced with the QU mixer that might help give you an easier workaround for adding an FX slot to multiple channels once the FX busses are consumed.
Good luck!
