Rotary encoder - Popup on the LCD when adjusting
I like being able to adjust parameters with the rotary encoders, but the LEDs are not accurate enough for fine tuning. It would be great if the rotary encoders would sense they were being twisted and would instantly pop up a visual likeness of that control on the LCD panel and show me that I am at, for example, a threshold of -3.4dB, and then have the popup go away when I stop turning the encoder. I would use the encoders a lot more often if that were the case. As it is, I most often use the touch screen because I can see exactly what level a given rotary encoder is setting as I turn it.
Kind regards,
Mark
You can press the SEL key in each encoder section if you need detailed visual info in the touch screen. It’s not an auto pop up but works well when you need it.
