Rotatives for Fx's PEQ
I think it will be nice if we could use those 4 rotatives buttons for equing fx eq.
I think actually, but maybe i’m wrong, we have to select each parameter by clicking on it,
and then, set parameters 1 by 1 with main rotary knob.
More than this, EQ knobs continue to move EQ band of the previously selected channel !
FX Return is like an input channel. There is a P-EQ tab in the channel view.
Yup, and just to add to the above…
Make sure you are selecting the FX return that you wish to EQ, and are not going to the FX Rack tab and going into the PEQ and trying to EQ there. Won’t work that way. You can only use the physical EQ controls on whatever channel is selected. Selecting an FX unit in the Rack’s tab does not auto-select the return.
And one more small addition:
Don’t forget that you could always adjust Frequencies and Gains also directly via the touchscreen.
So, even in your case, you’d need to use the “touchscreen rotary” only for Width.
that’s perfectly right !
select FX return before, my bad.
Thx all.
