Routing Main LR to AB jacks
Hi all.
I have my mixer about 2 days. I want to know How can I change the output of all channels to be heard on mono jack ports A and B?!
Thanks.
All you have to do is press the I/O key, tap Outputs, then Mix Out (both on the left side of the screen). Make sure you’re on the Local tab at the top as well; you probably are, though.
Then, scroll down to find the MainLR L and R rows. Scroll right to reveal the A and B columns, then tap the grey square at the junction of MainLR L and A, and Main LR R and B, so they go white. You can have the same mix going to multiple outputs, so this won’t affect any existing patch.
That’s it - you’re all set.
This is pretty basic I/O routing stuff, you should definitely check out the reference manual starting on page 17.
Thank you very much Peter.
I have already found it, and I wanted to put an image with it, for the beginners as mine.
I needed for my monitors, which I have already a pair of TS to XLR cables.
I saw that MainLR (L and R) ports can be assigned to all outputs ports, as well.
Best regards,
Vali
Ok. I routed MainLR to outputs. But now, how can I assign thouse outputs to strips to be able to PEQ them?
So, as you all understand better what I want:
I want to send Main LR signal to different outputs (and I did it, as it wrote in above posts). Each output will be connected to different active speakers. Each pairs of speakers has different factory EQ presets, so I need to lower some frequencies, or to louder some others. In this way I want to make for all different speakers almost the same sound.
How can I do this?
Thank you very much.
Sounds like you’ll be wanting to use a Matrix. This is what they’re designed for.
ianhind, thank you.
Can you explain to me exactly how to do that?
Managed to do it with matrix:
And I think it can be done with Groups, too! :slight_smile:
A matrix is better suited for this. Any time you have delay towers, broadcast feeds, balcony feeds, etc. You’ll want to use a matrix.
While a group will work for this, it’s better suited for processing a group of channels to be sent to your main mix.
Hope that made sense.
