Please, add this feature!
I use the Qu-Pac for live performance with some band and I need to hear every mixes or groups on my headphone.
Actually I use the PFL to do it but have limitations…
2nd suggestion:
Add the possibility to link mix channel 1-2 and 3-4 as the other last three stereo mixes.
It’s true, but if you were a musician would you use the PFL for your in-ear monitors? I think no…
This is my situation: I am drummer and sound engineer at the same time, as you can see on https://www.youtube.com/watch?v=4RXwQiPPlI8
I use PFL to check other mixes of every musician but I have to listen the PA mix (without clik). To do this, I created a Group (or stereo mix) and it would be perfect to route this signal to the headphone jack without using the PFL…
cannot hear the click in this way… unless you want to hear on the pa I should hear both pfl (LR+Click) but I couldn’t adjust the click volume just on my headphone. Other musicians have click as well
PFL a matrix or patch it to a headphone amp if you use a separate one.
Put click in it - you’ll need a mix or group for click only to do this, and then don’t put click into your own mix.
Then either:
a) Use the “Matrix All Sends View” (9.9 in manual) to turn off/on whichever mix you want to hear.
b) If you have a second iOS device (your phone?) then the, brilliantly powerful, QU-Contol app will let you set “Matrix Send On/Off” buttons for each mix/group as a quick way of swapping from one to another as well as volume for the matrix out. On a second page you could set volumes for each mix into the matrix too.
That is what that I do at the moment but is not confortable when you are playing… regardless of the touch screen or IOS devices you use.
I never said that it is not possible to listen to the different mix but it’s just not so easy, especially if you listen other mixes for any emergency while you’re playing…
What that I ask is to have the same options of “Alt-Out” on the headphone.
If you don't route the click to the output feeding your PA, you do not hear it.
LR and a stereo Mix is technically the same, with the pure difference that LR is named LR not Mix with some hard coded routings.
You do want to switch mix feeds to pre-fader in this configuration for sure.
You're totally free to route the click to LR but not to Mix (for example) 9-10, which feeds your PA.
LR will get be "your" monitor mix, and using PAFL you easily can listen to anything else (including the PA mix).
Every Mix/LR has it own set of volume control you are absolutely free to dial in different click volumes on any Mix/LR output.
I want to thank you all for every suggestion but I think that you guys aren’t focused on what is the problem. My english is poor, maybe I can’t explain better what is the real problem. I already tried all your suggestions that already knew. Believe me, I’m not a beginner. As a FOH engineer I use all main consolles and I know all routing possibilities, even of the Qu series but this problem it has nothing to do with this knowledge. Instead, as a drummer/foh engineer at the same time, it would be more simple with the same options as a Alt-Out. I know, I could use it with external phone amp but this output is already in use by bass player.
I hope that this feature will be implemented. In meantime…my temporary solutions and your suggestions are all the same
Thank you all
I think I grasp what you are suggesting. I am in exactly the same position being a drummer that also engineers the foh and uses iems and would like to do the same - essentially ‘properly’ route a mix to the headphone output.
The main issue with pfl or afl of a mix is the onboard meter then displays the pfl/afl level. I don’t want it to do that, I want it to carry on metering the main outs to the pa.
The issue with using, say, mix 9-10 for the pa, well, it’s kind of counter intuitive and, believe me, you want to avoid anything evenly vaguely confusing when trying to play drums reasonably well whilst making on the fly foh changes and mixing 5 band member’s iems including your own!
I would love a headphone setup page that allows you to ‘hard wire’ it to mixes (1-10) or main L/R (including a mono switch for channels 1-4 to tie L and R together). Then I can ditch the crappy headphone amp I use for my own iems.
->I would love a headphone setup page that allows you to ‘hard wire’ it to mixes (1-10) or main L/R (including a mono switch for ->channels 1-4 to tie L and R together). Then I can ditch the crappy headphone amp I use for my own iems.
I have the same request, a setup page to select what will be routed to the phones would be great.
I bought the Qu-Pac to simplify many things that I do when I’m playing.
i don’t want other machines. It would be extremly easy for me if they add a menu for the headphones with the same possibilities of Alt-out.
Remeber that Qu-Pac is not only a Rack mixer. I use it with a very complex configuration with mixed source signals (local + usb streaming).
Many audio interfaces have the features that I ask to the staff (headphone source config). It’s very simple to add this function to the Qu-Pac…I think.
Pleeeeeeeeeease
@DanZ: For the DAC-X3 you probably need sort of adapter from AES levels to Coax. @unbreak: Using the PAFL functionality its rather easy to listen to any audio source with the headphones without any menu.
Yes I have just been looking for a small type of AES [XLR] to audio out.
Thats not an easy find!
And even if you could source that youu would require a volume attenuator.
I guess you could ask A & H to put an Trim controll on the output surface/I/O Patch Tab/page
To Trim AES and whilst they are doing that if they could also put a Trim control for when sending PAFL to the Remote AR boxes as there is no volume control there either.
That would free up the local ALT out for other requirements.
There is plenty of room on that page
