After update 1.7 RTA analyser sometimes doesn’t work. Does someone else also has this problem?
I hoped for better sound when recording with this update but still crappy sound.
What do you mean by “doesn’t work”
The sound of the desk is pretty good to my ears - what issues do you have with it?
Crappy recorded sound is not due to the desk, it’s due to what’s coming into it. A poor choice of input, mic or DI, and lack of recording experience or unrealistic expectations are the problem.
I use my Qu-16 to stream live broadcast and to do professional recording for DVD and CD production. I do not do “crappy sound” and I use a Qu console.
You should be able to get professional results with the Qu. If not, look for the deficiency somewhere else in the chain. Do not blame good tools for shoddy work, my friend.
What Dick said +1 ![]()
…or the unlikely event you have a faulty mixer.
QU sounds tons better than many of the huge analog desks I traveled on the road with for years. I would put it up against just about everyone of them and that is saying something.
FTR. I started out working with tube mixers in the 60’s.
What goes in is perfect and sounds super with live work. But when recording it is like all depht is gone. Like there is a high pass filter active. I tried recording analog, digital, wave, mp3… With my old analog mixer I did hot have this problem. For recording I use a Tascam SS CDR200.
In this forum I have a topic about this problem but no one seems to have a solution.
About the analyser: when music is played, the analyser does nog react. The bars aren’t moving.
Where in the chain are you monitoring the signal and with what?
With live work you have room sound in addition to the PA sound, so naturally you’ll have more complex time arrivals which I think you are referring to as “depth”. If the inputs are good enough to do a decent live mix, one would expect them to be OK for other purposes.
What do your channels sound like at
Channel PFL in your headphones?
Recorded track played back through the board?
Live sound is like grilling a steak. Recorded sound is like trying to turn hamburger into steak…or the cow. It is different.
You’ve given some opinions and observations, but no real hard info to help assess whether or not there IS a problem and what might be done to alleviate it.
Don’t blame the hammer if you hit your thumb with it…
Having everything sound good live doesn’t equate to everything sounding good recorded.
What you may be applying in eq and processing to enhance the live mix may be affecting your recordings.
Are you selecting channel PAFL when using RTA?
Sorry Dick, must have been typing at the same time…
That’s OK. We’re all just trying to figure out what’s being done wrong and how to fix it. Another case of “I bought a Stradivarius but it sounds like s***”, but I’ve never studied the fiddle…
Free Internet sound lessons here…if you can put up with the attendant sarcasm. I guess it’s not free after all…
lol, true!
When recording or playing no EQ or filter is active. It is a midi track being played on a Tyros 4 and mixed out very well on a Tyros 4. When I record it straight to the Tascam, it sounds stays the same as the original. But I want to add some backing vocals and use it as a backing track played as wave or mp3 via the Tyros 4. So I use the Qu24 as a mixing console. Before I had this console, I used an old analog Midas mixing desk. With this analog console, when played back after recording the sound stayed the same as how the Tyros 4 sounds when played original. But now when recording with the digital Qu 24 it’s like the mixing desk cuts of all the depth. On the RTA you also can see the difference.
First someone told me there is too much of AD-DA conversion so I recorded via AES/Coax. No difference. All depth is gone when played back on the Tyros 4
I’m doing this for a long time and have a bit of experience so it’s not that I bought a Strad and don’t know how to play it.
There is no hot on the QU unless you choose to put one in. With a 48k, 24bit sampling pattern there is also no discernible drop off in sound.
Can you post a couple of tracks?
I don’t know how to post tracks here, but I can sent them by mail if you want.
Thanks in advance
You’re focusing on the Qu when it is just a part of a system/chain of devices. It is likely that in interfacing all the units, something is not matching up. This will likely be a routing/connection issue or an issue of something (sample rate/frequency/etc) not matching up.
Likely…
I’m wondering if this is a polarity reverse issue? Are you recording and playing back the keyboard in stereo? If so, are all your cables from the keyboard to the mixer, mixer to amps and amps to speakers in proper polarity? Is the polarity button turned on on one channel only? Are the return channels panned L/R or centered?
-Mark
Sound Cloud?
Other services are available…
Try recording some white noise from the signal generator as well.
There are no polarity problems. I double checked it all. I also tried recorden with the internal recorder of the Qu (via usb on harddisk). Same result. So in the whole chain it is really the mixing desk. I could rectify the los of depht with the global EQ during recording but I prefer not to because it is a bit like working in the dark… wich frequencies, how much…
