RUFX Global key SoftKey assignation
Hello everyone,
I would like to know if it would be possible to assign, for example, my SoftKey 15 to directly access the Global Key setting so that I can change it quickly.
My goal is simple: with a single button press, I could change the key between songs. Since all my songs are set up to Follow Global Key, this saves me from having to change the key for each song individually. I only need to modify the Global Key, which is exactly why I use this feature.
It would be even faster if I could assign a shortcut to the Global Key function on a SoftKey. On my Avantis Solo
Does anyone have an idea if this is possible or a workaround for it?
Thanks! :blush:
I might be misunderstanding, but…
Create a bookmark to the screen with the Global Key setting on it?
Yes à shortcut to the global key setting too see this more quickly. Do you know how we can do this?
If Avantis has the same feature as on dLive, then:
Go to your Soft Key set up page.
Select the soft key you wish to use as your shortcut.
Select Bookmark in the drop down selection box for what function you wish it to perform.
Click Apply. The softkey should turn blue if I recall.
Now go to the screen that you want to be able to quickly go to that has the Global Key setting.
Press and hold the Softkey you just set up, and then on the screen part, or all of it should turn Yellow, denoting what you can bookmark.
While still holding the softkey, press the yellow area.
You can now release the softkey.
To test it is working, go to any other screen.
Press the softkey you just set up, and it should hopefully bring you to the screen you wanted.
Pressing the softkey again will then bring you back to the screen you were on before pressing it originally.
I hope that this all works on Avantis for you. Fingers crossed.
