Can anyone share whether the S-Class equipment and C-Class equipment have any issues working together? Can they be mixed and matched? For example a DM0 with a C2500 or a C2500 with a DM64 etc…
Toph
Toph
They can absolutely be mixed and matched.
Thanks. Any feedback on how well the dLive and iLive play together? I.E. S5000/DM64 at FOH and iLive T112/D32 at Monitors.
The question is how you will split the signals…
Analog split > two seperate systems
digital split > one makes gain, the other gets the signal via networking card
All pretty seamless so far, currently exploring various connection options, Analogue obviously really easy, Ace works just fine. Waiting for the native Dante card for D Live to try that also. MADI will be handy for connecting to Digico, it will be interesting to see how AES 67 is handled. Pretty endless possibilities really, very comprehensive.
Analog would be easy but I sold off my analog split when i got my first iLive way back when… Can’t really justify spending money on another one at this point so I think digital is my option. Is gigaACE backwards compatible with normal ACE? Can you connect the second gigaACE port on a DM mixrack to the secondary ACE port on a iDR mixrack and have the audio pass or do you have to get the ACE card and add that to the DM? for my purposes I’d probably go the route of Dante if I had to buy a card for it.
I’ve considered the MADI option as I also have an SD8 but its getting used less and less these days. The dLive bug has bit me bad and now i just have to get the boss (aka Wife) to sign off on one. Have either of you used the dLive outdoors in the sun? How does the brightness/visibility hold up? The SD8 is terrible (at least the older gold Rev that I have) in the sun because of the angle and the dimness of it. my iLive T112 is dim too but the angle of the screen helps keep the glare down and so it still usable.
Second GACEPort is for redundancy only… as far as I know
readability in the Sun is good… better as on the iLive
You could pun an Ace card in a DLIVE port B+ Adapter ( M-DL-ADAPT-AX) and use the port B Ace on iLIve for digital link, this card will also take all the option cards used in iLive as I understand it. Currently have a Dante card in the D Live for connection to the Labgruppen PA amps which seems to work fine.
Certainly had no issues with screen brightness so far, just the usual FAT fingers on a touch screen ![]()
