S-Link switching
We have a venue with 4 separate s-link sockets located around the venue so a SQ6 mixer can be moved. These all go to a patch panel where the socket in use is manually patched to a single rack mounted AR84 Expander.
Can anyone suggest a Manual Switch located in or on the rake which could be used by the untrained person to select the correct venue socket, thereby routing that to the AR84.
I don’t want the patch board which is also used for D-Snake, Artnet, DMX etc being constantly mucked around with.
The AR box is only 100mbps.
There are plenty or articles on how to do dSnake, DX or ACE over network switches.
If you’re only ever going to patch a singular location you can wire all of them to the same vlan on a switch, plug that same vlan into the slink port and you’re off and running. You cant USE more than two ports simultaneously so the VLAN appears as a P2P connection, but you can be physically cabled to as many physical jacks as you need.
Hope that helps!
I believe he is NOT talking about network switches, but being able to switch between input panels without swapping ethernet cables.
