S vs C
Is there any difference in the audio between these 2 dLive series? That is to say, are the differences only in features and is the sound quality exactly the same between the C and S series boxes?
Shouldn’t be. The brain is the same on both kinds of rack unit. The only real difference between S and c class mixracks, are that you get 2nd/redundant gigaAce port, hot-swappable PSU, and extra IO slots IIRC. Same basic difference on the control surfaces if I’m not mistaken.
You are indeed correct, redundancy,power supplies and network expansion ports.
Can’t remember if there is a difference in the fixed I/O on the surfaces.
more fixed I/O on S-class
and more encoders in the EQ section and a full equipped input section (gain and filters with dedicated control)
and more user buttons
If you’re worried about sound and you understand the dLive concept the question you should ask needs to be about the difference between DM and CDM stage racks. They have the AD converters and back, they process everything and they fully work even if the surface gets disconnected. Processing is identical on CDM and DM. I don’t know about the AD converters and preamps. DM sure offers more expansion options and redundancy with surface connection and power supply.
Thank you for your replies!
Ok, so in trying to ask the correct question: are the Preamps and AD converters on the CDM and DM identical?
Bonus question: Can any S/C console connect and operate any CDM/DM Mixrack?
all devices are fully compatible
Yes and yes.
Yes, C-Class surfaces will work on DM Mixracks and S-Class surfaces will work on CDM Mixracks, with the exception of redundant network connection between surface and mixrack. That’s S-Class/DM exclusive out of the box or needs to be done by adding GigaACE extension cards.
Anyone regret getting the C class instead of the S class? There’s a considerable price difference for what seems like small surface/redundancy differences.
I currently own 3 DM racks, 2 S (5000/7000) series consoles and a C1500, I’m looking at changing out one of our DM32 racks for a CDM simply to drop the weight for fly shows (I can fly a DM32, but it doesn’t allow for a lot else in the pack, where I can get the same I/O count on a CDM32 5kgs lighter, and a smaller unit means I can also use a smaller pelican dropping the weight again. I’ve found no performance difference between surfaces, only workflow (and after using the C1500 quite a lot I’ve got all my workflow stuff down anyway - I use the soft keys & an IP8 for DCAs etc & it’s all pretty easy from there).
The only thing I now miss is the extra card slots in the S-class mixrack that the C-Class doesn’t have. Right now, that’s populated with my Waves card. But if I want to run an SQ for monitors, I’ll need to put a GigaAce card in that slot and move my Waves card to my surface. Not a biggie. But a change.
Thank you both.
So what changes when you move a card from the MixRack to the surface?
Mr X,
Audio wise, there is no difference in the slots. They are all 128x128 and fully patchable in the system. Redundancy risk in C without dual links/power.
If you are running GigaAce on the surface (is that allowed?), then you are sharing the network bandwidth of both consoles through the primary GigaAce.
I’ve also taken the stance that if the surface were to die, I could continue the show on a laptop/ipad, but any audio through the surface is lost.
Jay
Other that what Jay said, above, I’d need to reprogram the I/O telling it that the Waves card resides in the surface now instead of the mixrack.
Art
Hi!
I know this thread har been active… But, I have a question!
I am currently working on a S7000 paired with a DM48 and some DX:racks and is thinking of expanding to a C3500 with a DM0.
Would the workflow be different on a C3500 paired with a DM0 (yes, for the I/O-options)? How is the surface different form a S-calss? All I can find is that there is no redundancy in ACE and PSU (which is fixed), only 1 I/O port/slot, less soft-keys, no width-encoder for the PEQ and shorter meters above the channel-“display”. Is there anything else?
Blessings,
Alfred
Yes, besides the differences you mentioned, there are others:
  • the C3500 has fewer fader banks and fewer faders than the S7000 (but you’ve probably already seen that)
  • There is no direct access to preamp and filter besides the left screen
  • Also, you don’t have three buttons on the right touchscreen to switch widgets.
  • And there are fewer softkeys.
This makes it necessary to change the usual way of working a bit. But this is nothing dramatic, you can get used to it quickly.
The signal processing is the same, there are no differences. So you can use your previous showfiles - and you just have to adapt them to the new interface and the changed inputs.
