safe of the system GLD
Hi anyone! I have the question.
Can I connect two GLD consoles to one AR2412 to duplicate the system in the event of a system failure? For such connection the hub approaches? Is this provided programmatically?
Thank you!
You will have to manually copy the show to the second desk and physically change connections in a case of failure of the main console. Prepare to turn down your amps cause the 2412 will re-power the condenser mics and might give a loud noise.
No redundancy or double connection possible, as far as I know… :frowning:
