Can I save an EQ`s scene without save any other parameter?
I know that I can save EQ´s library but the thing i want to do is to recall a complete EQ previusly saved on all channels and then recall just the eq´s for those channels without modificate any other value on the channel?
Go to the scene edit page, in ‘processing view’ go to:
Input Channel Processing and expand the menu - then select ‘Parametric EQ’ and add it to the scene - this will add every input channels parametric EQ only to the scene.
If you wish to add EQ of only a few channels to a scene - select the parametric EQ and press the expand button - this will then then display all 64 input channels you can then add the specific channels you want to save the parametric EQ settings of.
