Can’t believe I have to reassign EVERYTHING when I play with Band A and then Band B and then back again. This is foolish, surely.
This is a little unclear as to what you’re describing is a problem but is it possible that you can use scenes to store each band’s settings and recall them at will? Or you could use shows instead if that’s easier for you.
perhaps I was unclear; let me expand.
when using CQ4You with Band A’s CQ18T, I assign all my channels/groups/levels on my phone.
the next time I play with Band A on their CQ18T, everything is just as i left it.
the following week, I have a gig with Band B on their CQ18T – totally different channels, totally different groups, totally different levels; rebuild my whole IEM mix.
a futher week forward, I go back to Band A on Band A’s CQ18T – go through the whole process again.
how hard is it to let a user save an IEM mix on their phone?
I feel your pain. Same thing for our Avantis. Same musicians, different instrumentation for different events. Different mixes needed for each.
Good suggestion.
Don’t forget to vote!
Use MixingStation
You can save layers differently for each
You can save mix presets for each
Unfortunately I’m out of votes.
Jeff
If you have run out of votes Jeff, maybe you are expecting too much from the CQ?
I also have an Avantis and have used many, if not most of my votes on that product. This particular post applies to that mixer as well as CQ.
Jeff
