When a scene change with a fade time mutes a channel, will it be instantly muted, or at the end of the fade?
Straight from the DLive Firmware Reference manual: the cross fader timer affects input faders, pan, mix faders, DCA faders, and send levels/pan.
Since mute is not specifically mentioned in that list, you can assume it is immediately executed when the scene is recalled.
One way around this is to have two scenes - one that doesn’t mute channels being changed in the cross fade and a second scene that is recalled automatically x time after the first scene is recalled (using the embedded scene option). This second scene would mute those channels, but it would be timed to be recalled after the cross fade timer had expired.
Yeah, thought so, when reading, but just wanted to be sure. I will use two scenes that fade an all inputs DCA before the mute changes.
Would be cool, to have an option, that it mutes at the end of the fade time though. ![]()
