Scene Recall Filter for Input Patch does not work
I‘m playing with the latest firmware V1.5.4.
I wanted to save scenes for switching between USB Inputs for virtual soundcheck and others for switching between local IO or SLink. For each of the scenes I set a recall filter where I blocked all except Input Patch.
Although I saved each scene correctly with the Inputs patched appropriate, recalling them does nothing. Input patch remains as it was before recalling.
No global filters set at all.
When I also allow „Preamp“, it works…
I think this is not as it is supposed to work…
since you switch between “preamps” and other inputs I guess you have to enable the preamps to make it work…
it is not simple to configure this…
I understand what you mean, but it’s a little bit misleading…
