I may be missing something here but I do not think so.
I am running GLD80 version 1.20.
I use many scenes in a show. Sometimes as many as 170 scenes. I am looking to be able to drop in anywhere in my scene list by scrolling to it, on the touch panel press “recall” and then “go”. So far no problem. I then want to simply “Go” to the next scene with a single button push and have the active scene memory highlighted on the screen.
It was not possible with V1.10, 1.11 or 1.12. Now it seems I still cannot simply find a soft key option that is “Next and Go” RELIABLY as well as indicate what scene I am on.
Presently I am able to select/recall/go to a scene. Then jumping to the next scene requires TWO key strokes of the soft key to increment the memories but highlight the scene I am not on. Subsequent scene recalls require only one stroke to perform “Next and Go”.
Can there be an option added to the soft keys for “Next and Go” and “Previous and Go” while showing where you presently are in the scene list?
The option for auto increment is not logical. I simply want to go from where I am now to the next scene and have it “Go” with one soft key press regardless of how I got to the scene I am presently on.
This will eliminate the present situation where the next scene is sometimes one keystroke away and sometimes two keystrokes away. Also sometimes it shows where you are now and sometimes it shows where you will be if you press F10 another time.
In the heat of a fast paced show not remembering if I have to press once or twice is a bitch.
If I need two keystrokes and I only press once nothing happens. If I press twice while only one stroke is required I skip the scene I really needed. What scene is highlighted? This one or next one.
“Next and Go” if you please. And please highlight only where I am NOW. I can look up and down the scene list if needed.
A simple way to reproduce this is to:
Set up/Soft Keys/Soft 10
Function=Scene/Next/Previous/Go
Mode = Go
Auto Increment = ON
Store 6 scenes. Scene 1 has only channel 1 fader up at unity all others off. Scene 2 has only fader 2 up. all others off. Continue that pattern until you have 6 scene memories saved.
Press function “Scenes”. On the touchscreen scene 1 “Recall” and “Yes”. Scene 1 is highlighted and fader 1 is up. Nice!!!
Now press soft key 10 (once) to recall scene 2. Scene 2 is highlighted but fader 1 is still up. Huh?
Next press soft key 10 (once) to recall scene 3. Scene 3 is highlighted but fader 2 now comes up. Oh boy!
Thank you for letting me vent. I purchased this board because I was told this would be fixed by maintenance release V1.10 but to no avail.
