Scene Recall Without Confirmation
I’m looking for a way to “GO” to a scene without the confirmation window popping up. I have “previous,” “go,” and “next” on softkeys, but I still encounter the window asking if I’m sure I’d like to recall that scene. In my application, that requires moving a hand from faders/softkeys to the screen, and by the time I do, the cue is then late.
Is there a way to bypass the confirmation for recalling a scene, or at least assign another softkey to be able to hit “yes” on the popup window?
Or is there a different workflow that would accomplish the same goal? I’m only using 20-30 cues.
Thanks in advance!
No confirmation pop-up is displayed when Go on Touch is active. Only use this option if really required.
Manual on page 30
Thanks, Steffen. That feature is a step in the right direction, but that means I still can’t recall a scene without touching the screen. When I use the softkeys, it still displays a confirmation window. Is there a non-touchscreen way to do this?
Figured it out. Thanks for your help!
@Duesenbert
and what was the answer you figured out?
When holding down option to access scene options, you can deselect “scene recall confirmation” and that will allow them to play as soon as you hit “go” or hit a softkey assigned to “go.”
