Scribble strip color vs text block
I was prepping an SQ and when labelling some inputs and mixes, I noticed that the text block (where you enter the name) appears the same color as the scribble strip, but on others the text block background is black with white letter. Are there 2 different places to change colors?
Cheers.
Maybe I don’t know what you mean.
You can also choose black as the background color in this text block.
Black letters would not be visible, so they are white - as well as on some other background colors (in the text block).
To give an example if I select input one and enter a name the text box is black. Yet the actual scribble strip is the default green. I can change it on the text block screen and it changes in both places. I can go to another random input and the text block will be green as well as the scribble strip. Pick another input and text block is black but scribble strip is green.
I don’t think I’m explaining this very well. May have to post a video.
Ah - ok - but I don’t think I’ve seen anything like it before.
you tube
Quick video showing the inconsistency.
It’s really new to me.
Sorry for ask, but are you using (one of) the latest firmware?
Because I found the following:
V1.4.3 Maintenance release
• ID-1558: Channel Name and Colour now update throughout system on library item recall.
Perhaps there were similar problems like yours, with using libraries.
I discovered the same phenomenon on my SQ5. Firmware 1.5.9
Could it be that it occurs on shows created before 1.4.3?
Or maybe it’s a bug in shows with scenes.?
(Because with BJ, i see, it is also in a scene.)
