Second dynamics slot for mixes
I would love to see a second dynamics slot on the mixes.
To be able to compress and duck and the same time.
Or to have multiple compressors on a channel. It’s very common to want to use an 1176 along with a LA2A compressor on a source.
Just curious, what’s the use case you have for ducking and compressing simultaneously? Compression for dynamic range control and then the ducker for automated level management based on another source?
Totally in favor of more options, though I’d probably prefer an extra dynamics slot on channels, if I had to choose.
On any of the busses would it be possible to convert the GEQ to another dynamics unit (gate, compressor) or even an FX unit (Dynamic EQ, Multiband Compressor or DeEssor etc)
When the bus is used as a Subgroup or IEM send I would favour the option to utilise an alternative processor.
Wal
I agree with this being an option.
For now you can get a similar effect using the dyn8 on the insert and use the setup key to change to 3band multi. This will let you duck out 20hz-18khz on the midband if you change it to external sidechain.
