I know, i know. Joins a forum and within minutes is demanding answers, actions, adaptions yada yada, but i promise, I’ve made every assumption that this is a quick and easy thing to add into a small update. And a quick search shows nothing that looks similar. And no other option to achieve this springs to mind after my last few years using these desks almost exclusively.
In amongst the soft key SEL MIX PAFL Scene you can Sel + PAFL, you can Mix + PAFL, but you can’t Mix + Select, and i can’t see a different option to achieve this.
Basically, so it’s possible to keep (for example) a Vox Grp on cans, and softkey an FX unit, send a bit more of an effect to a channel while tweaking the parameters, without having the FX Sends assigned to faders.
Can use MIX softkey and do the send level, or can use SEL softkey and tweak, or can do either of those with a PAFL (and listen to the dry send).
Cheers
Shealesy
