It would be super helpful if the select button on each channel sent a midi note.
I use MultiRack and have “hotkeys” setup through a midi controller to pull up plugin windows.
It would be amazing if when I select a channel on the SQ to control it’s gate/comp/eq/etc. it would also pull up my plugin window inside MultiRack.
Since midi has 128 notes per channel, it’s more than enough to have every input, aux, buss, to have a dedicated note trigger.
I agree and have also asked A&H this.
I can set Superrack to switch when you touch a fader, but select would be best.
+1 for sending a midi note of the selected channel
AND
+1 for vice versa
Select a channel via a midi note
dd
I support this request! Even if waves has still not released drivers for the m1 Macbook and the waves card in my SQ is just a dust cover…?
+1 if it was implemented it would be 2 way because its always the same message in or out from SQ
Please, add some midi messages for the select buttons!
It would be great to translate the midi messages to control a certain channel in SPAT, L-isa, Soundscape, Klang, Waves,…
Thanks in advance!
+1 This would be very nice when using Waves MR with SQ.
maw92
9
Bumping this up again, we need this! <3
