SELECT buttons send a MIDI note
We’re really loving the DLive integration with Waves SuperRack (and MultiRack) and the scene recalls are great. Can we get a MIDI note (option) added to the desk so that if we select a channel we can have it automatically also select that rack in Waves? So many things on the desk send MIDI like fader moves and mute, but not select.
+1 having the ability to integrate channel select midi messages with Waves would be a huge benefit to our workflow.
Big +1 here
Great! + 1
Big, big, BIG +1 here.
+1 !!!
Is there Really no update to this 4 years later!?
This Forum collects feature suggestions. ITS Not a To-Do list.
+1!
  1. Note on messages are already used by dLive for mutes.
  2. The Mix Rack sends and receives MIDI, not the surface. Although it is clear that a Surface can initiate a MIDI message somehow because a SoftKey can be programmed to do that.
  3. There would have to be a way to turn this select message off, because in a system with more than one Surface (including Director and possibly OneMix, MixPad, and IP controllers) there could easily selection chaos.
@msteel: your libes are all right, but the entire question was using the SELECT button (on several in- or output channels) to send a midi note-on (e.g.) to trigger other stuff!
that’s it.
+1 - this could certainly be used to create more automation that we currently have access too.
+1
+1
+1
dLive & Avantis !!
Yes! This is anecdotally probably the most requested feature at the moment right @ah_support ?? Democracy rules right?? :wink:
+1 good idea guys!!!
This would be amazing! Ideally it would be per-surface for those that sue multiple surfaces with a super rack instance per surface.
+1 here. With two surfaces connected to the same mix rack, a surface selectable option or separate connections by surface would be nice. However, I use different inputs on each surface (1-64 in room and 65-128 for broadcast) so it may not matter as the links would be in separate instances of SuperRack.
