Select PAFL - Multiple channels as a Modifier, not a global option?
Hey folks!
So I found the option for additive PAFL in surface settings. I find this, as a default “ON,” state, to be a bit annoying. It would be much more useful to have PAFL set as an x/or type behavior; (default state of the desk.) Then, while in this mode: a modifier key plus PAFL key activates “Additive,” mode. (IE on avid desks it’s shift + solo.) Small thing, but kind of a pain to have to keep hitting clear as opposed to deselecting a solo’d track, or double tapping another, not currently active solo, to remove active solos.
You can always assign a softkey to clear PAFLs
why create a softkey to clear the PAFLs?
on the surface there is already a button for this function, directly below the master level indicator
Yeah, I have to agree: Assigning a softkey is a waste of real estate and function, especially when the clear button is right within reach. It’s more about really having true x/or behavior in a quick-mix workflow; with a modifier, like the copy button or something, that allows additive behavior temporarily while the modifier key is depressed.
