Hi…Im new to sq 6
i want to record the service in to sony line pcm recorder via an xlr cable.
the cable is connected to output number 14
how can i get this output to the mix (ex number 6) so i can control the channel faders?
i need step by step instructions please
thank you very much
Hi Andrew,
first of all to get to some common ground – have you watched the official tutorial videos? Your question is covered there:
Best Regards,
Tobias
Push the IO Button under the screen.
Select the “output” tap on the left.
Select “local” on the top
Patch the wanted connection between output-bus on the left, and output socket on the top of the matrix
greetings
dd
thanks got it now
Merci
