There’s no way to run backing tracks in monitors and have them fade with the house, is there?
+1
Output from Input to Aux requires Pre/Post switching for each channel.
I want to send Pre to band members while Playback (DAW) should be Post Fader.
+1 !!!
+1
Yes please!! This is an absolute must!!
+1
+1 , I need it for halfplaybacks with different backround music level too…
+1, for the fx!
This is exactly what I need, Selectable Pre/Post for all sends for independent channels, not just globally set on outputs. This one is important as it is a major workflow headache.
Plus 1. Agreed. The only way you can do it currently is to use a spare post fade Aux - output your backing track from that, then physically cable return that aux output back into a spare input channel then send that channel to the pre fade aux’s going to monitors. BE CAREFUL! Don’t send it back to itself!!! Not great but it is a workaround.
Please A & H give us Pre Post per channel to Aux’s
Gonna bump this topic again - CQ PRE/POST fade aux sends selectable per channel -please???
