Our church has an SQ7 and we currently use a monitor mix for our livestream. We want to apply a separate reverb on that mix that doesn’t go out to the main L/R. Is this possible and if it is, how is it. Thanks!
On that reverb return set that monitor mix send to pre fade and keep the main LR level turned down or just un assign the that reverb return from the main LR mix.
I prefer to add a pair of omni room mics to my stream mixes. The actual room and any ambient noise therein adds a lot of life to a stream.
Thank you so much. Pretty easy and worked great.
If you add room ambient mics be sure to un-assign those channels from the main LR mix.
