Hi everyone,
I recently got a for a try out
CQ-12T mixer and need help setting up a separate mix for my in-ears. On my previous SQ-5, I could copy channels and assign them to different aux outputs, creating an independent mix from the main output.
Is this possible on the CQ-12T? Or do I need another method, like signal splitting? Any tips or experiences would be greatly appreciated!
Thanks in advance!
Normally, you wouldnât need to âcopyâ channels for an additional mix on the SQ either.
Youâd only need to do this if you really need different EQ and dynamic settings for each channel in the main LR and your in-ear mix.
However, with the CQ, you canât patch input jacks to two channels.
So youâd really have to split all affected channels before the inputs.
Does this procedure on Fader window not work for you?
If you want to send the âGuitarâ with separate EQ and compressor settings to Main LR and âBobâ, it wonât work that way.
You would need two independent input channels for that.
