separate routing from send levels for scene safe
I’m still working on a show we did, to optimize the scenes.
It would definitely not be that much work if I could just put the routing ON/OFF buttons scene safe and not the send levels. Actually that would even solve the whole problem.
Now I need to go through every single scene to check the setting for 8 auxes (monitor feeds) and check them scene per scene. I only want them to use channels 33-64 and not 1-32 as those are used for FOH.
It would however also be nice to get the routing on/off buttons out of the scene at all, so you don’t need to worry at all.
Wouter
+1
and saving trim or amp on surface ,not possible ,although i hope i miss something
cheers
dave
allen&heath iLive-144 /idr 10 / idr 48 /dante (i want midi in dante!)
