Setting Up Direct Outs for Multitrack Recording
I’m trying to setup my Qu-16 for multitrack recording with my DAW (Pro Tools). In the I/O Patch Setup for USB Audio, I see the option to select “Direct Outs” as my CH/ST Grp source, but I also want to be able to set the tap point to Pre-EQ (Pre-Fade), but I don’t see options like Pre-EQ (Pre-Fade), Post-EQ (Pre-Fade), or Post-Fade available.
Any advice on how can I ensure that my CH/ST/Grp source is not only set to “Direct Outs”, but also that the tap point is set to Pre-EQ (Pre-Fade)?
You tap Direct outs and it turns to inserts… that’s what you want.
