If this is a case of needing to combine two sources to one input and it sounds like
they are active line level units then as just mentioned you really need/should use
a combiner.
Here is a Whirlwind isolated combiner similar to the Stageline model.
As for combining two dynamic mics into a signal channel, I’m going to guess
at one point or another most of us here have used a Y cable to combine two mics
when at the last minute we need that one more for an extra drum tom!
To clarify, I want to put 2 x input sources into one source on the mixer (on two channels for stereo)
The digital decks are a Pioneer XDJ-XZ all-in-one DJ unit, which has its own mixer built in, so it would be line level leaving the Pioneer before it went into the SQ, although the other source is a eurorack module (which accepts line level, but I’m unsure of it’s output voltage)
By the sounds of your replies it’s not as simple as just using a splitter, but with this new information, do you you think I would still require a combiner?
I see some of you have mentioned stage boxes, which I was considering a few months ago.
As I understand it - off the top of my head - the SQ5 has 48? internal channels. If I am currently using all the physical inputs on my SQ-5 (no USB inputs or outputs are used) how many more channels would I have available to me, disgregarding the amount of physical inputs a stage box would give me?
Hope that makes sense. A stage box is a lot of money for me, but if it buys me more inputs internally it might be better to futureproof myself that way!
Your SQ5 has 17 mic preamps (including talkback, which can be used like any other), and the 3 stereo inputs. So that’s 23. Adding a stage box would give you another 16 (or 8 or 24 if you choose an AR box)
You can use all of these at once , up to a total of 48.
Thanks for the link @MarkPAman - I know what I need to avoid.
Unfortuneately I have used all the other inputs you mention, except the mini jack on the front of the desk.
Does anyone know if I will lose any quality going from the 2 x XLR or 1/4" mono out of my Pioneer mixer, into a joint stereo mini jack into the front of the SQ? Not ideal but it will do for now!
you will lose no quality, but might lose some reliability in the long term with the smaller connector.
we use it with a special cord to connect an iphone with music. plugs on one end for the board and another one for the phone.
I had expected the phone would have poor quality but I got pleasantly surprised.
I normally get them custom made, but the price I just received was quite high. I was about to looking for a pre-made cable, but now you’ve said you don’t find them easy, I might just get them to make it
